Syncing Airtable to MSSQL SQL Server Management Studio(SSMS)
Hello!
I am trying to sync my airtable to a SQL Server Management Studio Database. Essentially, I want the database to update every time I make changes to the airtable. Is this possible via code? I have looked everywhere on the internet to find a 3rd party solution, but none seem to accommodate for MSSQL, and if they do, they are faulty.
Has anyone solved this issue using Python code, so when the code is run, the database updates based on the airtable?
  • September 21, 2023
try fivetran.com it works with the free plan and airtable free plan. It will automatically detect schema changes and no need to create your SQL tables.
MJen
Forum|alt.badge.img+7
  • December 29, 2024
I don't quite understand your question. Could you explain in more detail what you want to do?
SQL Server Management Studio Database is just a tool for accessing and viewing the database.
If you need integration between Airtable and SQL Server, you can try Skyvia. This is a third-party tool that handles this task. It allows you to perform ETL, ELT, and sync approaches. You can find more details here.
