Tracking equipment
  • June 14, 2020
  • 4 views
Hello community,
Hope that you may help me with this one.
I am trying to build a system that will help my with inventory tracking. So far so good, and there are many great templates and tutorials out there.
HOWEVER, I haven’t figure out yet how to solve my issue: From time to time, employees take equipment from our warehouse for a specific project, and I want to keep track of everything.
I thought about making a table for each time someone takes something, and then finding a way to reduce the amount of available items from the amount of items that went out from our warehouse. but - I have no idea how to do that.
Making a row for each project is not ideal as well, because each project uses several items with different quantitates.
Any suggestions or tips?
THANK YOU!!!
Best answer by Aron11
Hi there,
There are a few ways to do that.
One way is to create a check-in/check out table where you add a record each time someone takes something out or in and then use rollup/count fields to figure out whether it’s in or out (odd number of records -> out, even -> in).
Best
Aron
Want to learn Airtable? Join me for a webinar at airtable.com/webinar
  • June 17, 2020
Hi there,
Best
Aron
