Hi James, yeap, check this out. To view the formula, duplicate the base by clicking the title of the base at the top of the screen and then click the three horizontal dots on the right
The idea is we just make a rollup field inside the Offices table of the linked Submission records, and use the aggregation formula of COUNTALL(ARRAYUNIQUE(values))
This was a fun one to solve, and made me chuckle when I figured out the solution, so thank you for the brain teaser
Thank you this worked! I was close I was using Count instead of count all so it wasn’t working as I wanted it to.
