Using IF/Concatenate for dimensions
  • May 3, 2023 4:18 PM UTC
  • 104 views
Dgmknzgrl
Forum|alt.badge.img+7
I'm trying to represent dimensions using concatenate and IF statements but it's not working.
This is what I'm going for
If HEIGHT and WIDTH then H x W in.
If HEIGHT and WIDTH and LENGTH then H x W x L in.
If DIAMETER then D dia.
I managed to get the first two fields working, but I'm not sure how to get the dia field to show up.
IF({Length (in)}=0,{Height (in)} & " x " & {Width (in)} & " in.", {Height (in)} & " x " & {Width (in)} & " x " & {Length (in)} & " in.")
I also tried the following based on reading some other threads and the formula works (without the & so I didn't get too confused), but doesn't actually produce anything (the Dimensions field stays blank):
IF(AND({Length (in)}=0,{Height (in)}&" x "&{Length (in)},IF(AND({Length (in)}>1,{Height (in)}&{Width (in)}&{Length (in)},IF(AND({Diameter (in)}>1,{Diameter (in)}))))))
Any help would be appreciated!
Best answer by Ben_Young1
Hey @Dgmknzgrl!
Give this a shot!
TRIM( IF( {Height (in)}, TRIM({Height (in)}) & IF( OR({Width (in)}, {Length (in)}), " x ", IF( NOT({Length (in)}), " in.\n" ) ) ) & IF( {Width (in)}, TRIM({Width (in)}) & IF( {Length (in)}, " x ", " in.\n" ) ) & IF( {Length (in)}, TRIM({Length (in)}) & " in.\n" ) & IF( {Diameter (in)}, TRIM({Diameter (in)}) & " dia." ) )
 Here's what it looks like when used:
Be sure to check that your field names are properly formatted if the formula throws you an error.
  • May 3, 2023 5:03 PM UTC
@Dgmknzgrl I would approach this in this manner:
IF(AND({Height (in)}, {Width (in)}, {Length (in)}=BLANK()),
CONCATENATE({Height (in)}," x ", {Width (in)}),
IF(AND({Height (in)}, {Width (in)},{Length (in)}),
CONCATENATE({Height (in)}," x ", {Width (in)}," x ",{Length (in)}),
IF({Diameter}, {Diameter}, BLANK())
This first if statement looks for a value in height and width but a blank value in length and returns a concatenation reflecting that
The second if statement looks for a value in height, width, and length and returns the appropriate concatenation
The last if just looks to see if there is a value in the diamter field and returns that if there is one.  If there isn't any of the these conditions it just leaves the field blank.
Hope that helps.
Ben_Young1
Forum|alt.badge.img+22
  • May 3, 2023 5:48 PM UTC
Hey @Dgmknzgrl!
Give this a shot!
Dgmknzgrl
  • May 3, 2023 9:01 PM UTC
Hope that helps.
@Brian_Swanson thanks much!
