Hi everyone. I’m trying to write a formula that shows whether or not a date is a UK Bank Holiday. I’ve been using and IF formula that refers to a field with numbered days of the year, i.e. where January 1st = 1, December 31st = 365, for all days of 2019. So far my formula is IF({Day of year}=1, “Bank Holiday”) because New Year’s Day is a Bank Holiday, but I want to display “Bank Holiday” for every date that is a Bank Holiday i.e. a list of numbers between 1 and 365. Can I include all those numbers within the same formula, or is there another way to do this? Thanks.
Page 1 / 1
You can use a SWITCH()
statement here:
SWITCH(
{Day of year},
1, "Bank Holiday",
37, "Bank Holiday",
etc...
359, "Bank Holiday"
What this says is,
“Look at the value of the {Day of year}
field, and if its value is 1
, return "Bank Holiday"
, if its value is 37
, etc… and if its value doesn’t match any of the options listed, do nothing.”
You may also want to check out this excellent work by @W_Vann_Hall, as it may prove useful to you:
U.S. Holidays for WORKDAY() and WORKDAY_DIFF()
