Over the course of a project we will be conducting a series of feedback surveys, each with the same questions, but after different events. I plan on storing responses to each survey in its own table within a base. Is there a way to duplicate the form to different tables? I will need to do some minor updates (e.g., changing the introductory text), but the questions would be the same.
Way to duplicate a feedback form with different tables for different events?
Best answer by ScottWorld
You cannot do that, and it is typically not a good idea to create different tables for collecting the same exact information.
Ideally, you would want to create just one table for your form answers and then you can filter based on event.
This is because a database app is supposed to reduce redundancies and create powerful automations & integrations. This can only be accomplished if you store similar records in the same table.
It is also highly recommended to use Fillout’s advanced forms for Airtable.
Fillout is 100% free and offers hundreds of features that Airtable’s native forms don’t offer, including the ability to update Airtable records from a form, display Airtable lookup fields & Airtable rollup fields & Airtable attachments & formulas on forms, dynamically & conditionally filter linked record fields by any values that you would like, perform math or other live calculations on your forms, accept payments on forms, create multi-page forms with conditional paths, create new linked records on a form, and so much more.
