What happens to my records if I decided to downgrade to free plan?
Good day! I just got upgraded to Plus for a month. May I ask what happens to my records if I decided to downgrade to free plan?
Thank you!
Forum|alt.badge.img+20
  • April 19, 2021
Hi @Bille_Janssen_Lagard!
When you downgrade, you will be given a warning alert that you have records over the limit.
You will have to delete them or split your base, so you have no more then 1,200 records per base, for a free plan
Hope this helps!.
Mary Kay
  • June 4, 2024
I have the same question - I purchased the Team plan for the month that I needed it for my project, but what happens after the warning that states that I have "26 days left"? Will my data be deleted? Or will I simply be prevented from adding more records till upgrading again?
