What is wrong with this IF Statement?
  • February 11, 2020
  • 34 views
Best answer by Jeremy_Oglesby
It’s missing an opening parenthesis, and it’s got an an unparsed date string.
You need to use DATETIME_PARSE() to parse the string into a DateTime object to compare with your Date field.
Also, you may want to use the IS_AFTER() date comparison function.
I think this should be your equivalent formula:
   IS_AFTER(
      {purchase-date},
      DATETIME_PARSE("02/01/2020", 'MM/DD/YYYY')
   "Yes",
   "No"
  • February 11, 2020
   IS_AFTER(
      {purchase-date},
   "Yes",
   "No"
  • February 11, 2020
Thanks you very much
You’re welcome :slightly_smiling_face:
