Building a frontend UI framework for Airtable
Forum|alt.badge.img+8
Hey folk! Joel here the founder behind Paytable ðŸ‘‹
We're working on something new to visualise Airtabl e that gives you the full editable code you can embed or use on any site builder, LMS or tech stack called basefront app.
So basically input your airtable creds and the generator creates a frontend which you can apply custom css and all the good stuff like tweaking the code to add webhooks or whatever you like.
More about it here: https://x.com/J__Rosen/status/1773027720731013221?s=20
Hoping to launch with the next few months:
Check it out https://basefront.app
Be the first to reply!
