I built a Custom ChatGPT to help with Scripting.
Hey Airtable Community! 👋
I've pooled my learnings about Airtable scripting and created something for us 'no'-coders: Airtable Script Helper. It's my first project since OpenAI launched custom ChatGPTs last week, and I'm excited to share it with you!
[REQUIRES CHATGPT SUBSCRIPTION]
🔧 What It Does:
  • DIY Scripts: Helps you create Airtable scripts or edit existing ones, whatever you need.
  • It has been fed with some key considerations/best practices to be mindful for when creating scripts, so it should be better at helping you create scripts than vanilla ChatGPT
  • Even if you have never written a line of code before, you may try it out. I too started using scripts only After ChatGPT was launched. 🙊
🚀 Try It Out! Give Airtable Script Helper a spin and start building your custom scripts today. Let me know if you encounter issues and you think it is fixable. Any feedback is welcome.
For anything more advanced, I'm just a click away: VikasVimal.com.
Happy scripting!
This is fantastic 🙂
  • March 24, 2024
This is an unbelievably valuable resource. Thank you for putting this together!
@Vikas_Vimal2 I just want to say thank you & that I just used your Airtable Script Helper - it gave me a nearly perfect code for what I need!
