Transform Your Data Into Radar Charts Right Within Airtable! ๐Ÿ“Š
  • September 25, 2023
  • 14 replies
  • 300 views
Forum|alt.badge.img+8
I hope everyone's doing well! I wanted to share a solution to an issue I faced last nightโ€”something I think could help many of you, especially if you've been stuck like me, looking for ways to visualize your data using radar/spider plots.
📌The Challenge
In my line of work (and Iโ€™m sure itโ€™s the same for many of you), I frequently need to compile multi-dimensional profilesโ€”think student grades across multiple subjects, or sales metrics across different KPIs. Pie charts and bar graphs are good but don't quite capture the essence when you have to look at 5 or more variables simultaneously. I've always felt that Radar Charts could be the perfect solution for these multi-faceted profiles.
📌The Solution
After a bit of tinkering and some late-night coding, I came up with an Airtable base that generates radar charts directly from your records. I found this incredibly useful for embedding in reports and using in the Page Designer block for quick presentations.
📌How it Works
1️⃣The DataTable table is where you can input the metrics for your radar chart, with fields like Name, Var1 to Var5, and a special ChartAttachment field. 2️⃣ The INSTRUCTIONS table contains the pre-installed script and other helpful guides to get you started. 3️⃣ Just select a record and run the script. Your radar chart will be generated and attached to the ChartAttachment field.
You'll need an API key from RapidAPI. More Documentation here.
👀Check it Out
I've published the base on Airtable Universe. It's more of a "Show and Tell," so feel free to check it out, make a copy, and see if it fits into your workflow. Here's the link to the base.
📌Use Cases
I can see this being super useful for educational profiles, student grades, employee performance reviews, or any other data set where youโ€™re looking at multiple variables for the same record at once.
Let me know what you think, and if you have any questions or suggestions. I'd love to hear how you're using it or planning to adapt it for your needs.
Best, V
Hi, Vikas_Vimal2,
I'm trying to access your example base, but it seems to be misplaced. Is it available anywhere else?
  • February 20, 2024
Hi, Vikas_Vimal2,
Oh, Seems like the base moved. I've updated the link. Please try now.
It worked fine... minor adjustments needed, and it's already working!
Thank You so much!!!!
Forum|alt.badge.img+7
  • February 25, 2024
hi, thank you but its impossible to copy the base in my workspace, i think there is a bug some where!
can you advise please ?
  • February 25, 2024
You should be able to click โ€˜use templateโ€™.
  • February 26, 2024
Thank you, yes this what i tried to do but i get error page, i tried in many browser and impossible to add it 😕😕
I get this :
  • February 26, 2024
I get this :
I've no idea why that happened, but you could explore it, copy the script from Instructions table and use the API.
  • February 26, 2024
I think that the problem is in this script, when i click on explore it open the page but tha sidebar where script is located is not showing, its stay on "loading" state.
Is it possible to paste the code here please ? and if possible, crate another table without script until i can copy it ? thanks a lot
  • February 26, 2024
https://airtable.com/app9w9iOOX27AMS3y/shrJXQaQhKhW9KpCQ
This link should work.
  • February 26, 2024
Thanks A LOT its working !!!
  • February 26, 2024
i pasted the code into new script and add the api key from the other website,
when i click run i get this :
ERROR
SyntaxError: missing ) after argument list
    on line 1    at E on line 1    at Generator.<anonymous> on line 1    at Generator.next on line 1    at r on line 1    at a on line 1    on line 1    on line 1
  • February 26, 2024
ERROR
Worked finaly, chatgpt helped me to resolve it 🙂
I get this :
Jan, I faced the same error message, but exploring the base, copying the script from the instructions table was able to run it...
Vikas_Vimal2, I'm not a programer, and that 'might' be the issue, but I was trying to customize the code to run after a click of a button for that record, but the function 'map' doesn't work.... any tips?/
  • February 27, 2024
Hello, i tried to achieve this with a button but cant figure out,
The ideal is to use it in as in automations !
Another tip, i think quickcharts.io is easier to use and there are more options for customization, any body tried it ? here a tutorial : https://quickchart.io/documentation/integrations/airtable/
