63780members
148134posts
Community Activity
Need Help with an unusual Filtering Requirement
I have an unusual filter requirement. So how I need this to work is: I only need to go into the view on Mondays and Tuesdays. The data will be imported in every Tuesday. Once that data is imported I need to see data from the previous week, For exampl...
  • 17 Views
  • 0 kudos
automate emails to client with quarter report
 Hi,For a property management company, how should I go about creating the next quarterly report?I have organized a board for:AssetsFaultsClientsEvery quarter, I aim to send each client a separate email containing a report detailing:The income generat...
  • 22 Views
  • 0 kudos
Make Automations List Searchable
What is the proposed idea/solution?The automations list should be searchable by automation name. When there are lots of automations, finding the right one is annoying, even when organising them in sections. How does is solve the user problems?Faster ...
  • 59 Views
  • 2 kudos
Formula If and dateadd
 Hello airtable community, I have this following formula but dateadd does not display the operation in the result thank you for your feedbackFranck IF({Date début package} != '', {Date début package},IF({Date début expl 23} != '', {Date début expl 23...
  • 55 Views
  • 0 kudos
Merging Duplicates
Hi Airtable Community,Hoping you can assist.I'm having trouble merging duplicate records, (Keeping the original record and updating  specified fields from the new record, then deleting the new record once complete).I have no java script knowledge wha...
  • 44 Views
  • 0 kudos
Vee by 4 - Data Explorer
api call
The following bit of code is intended for a Script block to pull data into airtable it was written by chatgpt I cant make this work for the life of me async function updateRDAPData() { let table = base.getTable('Wucy'); // Correct table name ...
  • 182 Views
  • 0 kudos
Using automation to link records
One if the biggest pain points I run into every day with Airtable, is trying to link records automatically.  A {formula field} that needs to feed into {linked field}.  If only there is an easy way to do this, any suggestions? My current solution is r...
  • 50 Views
  • 0 kudos
Resolved! Concatenated text field in automation
We needed a "quick" way to see that a calendar entry was canceled (in the label, which is a text field named "Short Name") without typing it. (We use a check box to "cancel" the event) Forgive me, I'm new. This may not be the most elegant way of doin...
  • 55 Views
  • 0 kudos
Announcements
Airtable Top Contributors | March 2024
Happy Spring, Airtable Community, and welcome to the March edition of our Top Contributors post!  Each month, we love to shout-out the incredible individuals in our community who go above and beyond ...
Announcements
Airtable is now HIPAA compliant
喙 Exciting news for healthcare providers and organizations! Airtable is now HIPAA compliant and ready to support your critical work.  We understand the importance of protecting sensitive patient dat...
Announcements
Introducing Airtable AI
Announcements
Announcements
