We love the new blocks features - particularly the Twilio Block.
We are running multiple large events and are moving away from event software provides as they are expensive and unreliable. With the new Twilio block we can almost run the entire event logistics from Airtable!
However, I have one feature request that would make this feature complete: Scheduling.
As far as I know, one can atm only send real time texts through this block. Scheduling would take this to a new a whole new level. Please consider adding this!
I agree! I would like this feature added in too.
@Vegard_Haveland while it would be a nice addition to have inside Airtable, i’m quite sure that you can achieve this with a simple Zapier integration.
Simplest way to do this would be to have a date field, say {SendDate}, as well as a view (TriggerView) that has a filter where {SendDate} = Today. With this setup, you will have a new record show up in the (TriggerView) view on the day it needs to be sent.
Then, in Zapier, your Airtable trigger event will be “New record in view”
–> Action: Send Twilio SMS
I think I need to play with Twilio more, am trying to pull phone numbers from a (active employees) view to send the texts time card forms webforms to (active employees) at the same time every day.
