Automation copy multiple records after checked box problem
  • March 31, 2022
  • 17 views
Forum|alt.badge.img+8
Hey everyone
Having problem with an automation when a record is checked, a copy of the record is made in another table. The problem is that it works ok when doing it slow and one record at the time, but I want to take all the checked records at the same time or to speed up the automation, its very easy that a copy is not made because of the slow automation.
Any ideas?
Regards
Jesper
Databaser
Forum|alt.badge.img+25
  • April 7, 2022
Yeah, I have had the same issue when using the fill handle for these purposes. Not sure if it’s a permanent Airtable thing or if it was just bad timing with a slow connection (on their side or mine).
