I've set automation to create record which get value from a field when a value is entered to that field (use trigger type "when record matches condition"). But the automation is real-time triggered when the typing has not finished yet, so the getted value is incomplete. For example, enter "300" but only get "3". How do I fix it please? Thank you a lot.
automation problem: incomplete value
Best answer by ScottWorld
Unfortunately, as you’ve discovered, Airtable won’t wait until you exit the text field to trigger the automation.
So you’ll need to trigger your automation differently — such as adding in a checkbox field or a single-select field — as part of the trigger conditions.
There is a good discussion on this topic here:
https://air.tableforums.com/t/what-are-the-pros-cons-to-using-a-checkbox-vs-yes-no-single-select-vs-text-field/915
p.s. For more advanced automations where you might be using Make’s advanced Airtable automations, you’ll want to use a similar trigger, but then send a webhook to Make using a script. I discuss that in this thread: https://air.tableforums.com/t/sending-airtable-data-to-an-external-webhook-such-as-make-com/159
