Issues with images in my automated emails not rendering
  • April 29, 2024
  • 155 views
Hi all!
I've created an automated email and am trying to include our company logo as a footer.
The code I've used in the input is:
<img width="200" height="50" src="https://www.the-page.co.uk/psoostoo/2022/05/The-Page-LOGO-2048x486.png">
In the preview, this works perfectly (see image), but when I ran a test to my own email address, the image didn't render and I just saw a grey box (see other image).
Any idea on what I'm doing wrong or what the issue may be?
In your screenshot the Airtable logo isn't loading up either, so it seems likely it's localized to your environment somehow.  Does the email look like that on another device?  What about on another network?
  • April 29, 2024
Very strange... your exact code is working for me when I send an email to myself from Airtable's "Send Email" automations.
See both of my screenshots below.
Perhaps your browser is blocking the loading of certain images?
If your browser isn't blocking anything, then you may want to report the issue to support@airtable.com.
Alternatively, you can try sending your emails with Make's advanced automations & integrations, and see if it works there.
If you’ve never used Make before, I’ve assembled a bunch of Make training resources in this thread. For example, here is how you would instantly trigger a Make automation from Airtable.
Forum|alt.badge.img+31
  • April 30, 2024
As I mentioned above, the browser is most likely blocking images.
  • May 2, 2024
Thanks Scott - strangely, when I changed the email source to outlook from the native airtable automation, it worked fine. But I agree must a local issue as the original worked when I sent to a gmail test account!
  • May 2, 2024
Thanks, I think you're right, seems a local issue. It worked when I was using my home wifi, also worked when sending to a test gmail account.
