Linking Columns Through Automation
  • June 24, 2021
  • 44 views
Hi Community,
I have a table A, which has 3 fields. Field 1 is Name, Field 2 is Role, Field 3 is Skill-Level.
Simulated data for Table A:
John, Singer, High
Michiel, Pianist, Medium
Zule, Guitarist, High
Table B has 3 fields. Field 1 is Name, Field 2 is Phone Number, Field 3 is Email Address.
Simulated data:
John, 12345, john@music.com
Zule, 67891, zule@music.com
Question: is there a way to ensure that when I add any new record in table A, only new records in table A with Skill-Level = High are automatically added to table B?
Having combed through Airtable’s functions, I am sensing that this is not possible without using Zapier or Integromat or some JS code but I hope to avoid these options. Please advise, thank you!
Hi Kamille,
It is more for a strategic purpose, where not all entries in table A would be in table B, although they would share some columns.
Then my recommendation would be to have one table with two (or more views): one view with all records and all fields shown, and one view that is filtered to show only records where {Skill Level} = High and with certain columns hidden.
Again, you could store this subset of data in a separate table and use Automations to link records together, but it does not sound like your use case makes it necessary to rely on this more fragile solution.
Kamille_Parks11
Forum|alt.badge.img+27
You could do that with an Automation, but may I ask why you have two separate tables for this instead of just using filtered views?
  • June 24, 2021
Hi Kamille,
Kamille_Parks11
Hi Kamille,
