Record matches automation not running for new entry from form
Topic Labels: Automations
324 0
Will_Henderson
I have an automation set up to trigger when a single line text field in a new record is empty. The empty field is then populated with some text.
The trigger works as expected when a new record is added directly in the airtable base but when an entry is added via a form, nothing happens.
Any thoughts why this is happening?
0 Replies 0
