Advanced filtering not working
Topic Labels: Base design Views
542 2
AlexW-DP
Hello, trying to set an advanced filter and it's not working.  Thinking I'm perhaps missing something obvious?  Looking to filter for projects that I'm working on and which are not "done" or "abandoned" or blank in their status.  See screenshots of my filter and what is currently displaying on the base (currently still showing done/abandoned items).  Thanks for tips/suggestions!
Alex
16 - Uranus
16 - Uranus
Hmm, try changing that "OR" in "Or Status is not empty" to "AND"?
16 - Uranus
16 - Uranus
Thanks, Adam - that worked!  Had a moment of logic brain freeze there.
