Best Practice for a base for entire company
Topic Labels: Base design
411 1
Drew_Nemer
7 - App Architect
7 - App Architect
I am trying to build my company a tool that would be used to track all the program specialist’s monthly re-examinations.
I plan to use different views to allow each Program Specialist to display their progress in completing their monthly re-examinations.
However, I am questions about how to make this possible without running into any issue where Program Specialists might inadvertently alter or change someone else’s log–by accident.
Is there a way to lock views so that only specialists can interact with their own view?
You can’t set permissions for views — you can only set them for fields & tables.
It sounds like you could really benefit from implementing a portal system like the one offered by MiniExtensions, where each user only sees their own records & can only edit their own records:
