Create a Base with in a Base
  • December 7, 2020
  • 38 views
Can you create a Base within a Base?
Best answer by JonathanBowen
Hi @Charles_Morris - the short answer is “no”, but if you can give some more detail on what you are trying to achieve, there might be a way to do that.
JonathanBowen
  • December 9, 2020
  • December 10, 2020
HI @JonathanBowen, thank you for your response. I was trying to figure out the best way to categorize multiple bases within the workspace. I realized that the individual bases would suffice. Thanks again!
