Formulas for numerical scores based on 2 multi-select fields, each adding a different number
  • October 4, 2023
  • 18 views
How do I have a formula based on 2 different multi-select fields, that will add a specified number to the resulting formula, based on how many options were selected for each multi-select field?
Remember that each multi-select will be adding on different number.
Here is my formula so far.
(IF( {Pull Factors Attract}, LEN({Pull Factors Attract}) - LEN( SUBSTITUTE( {Pull Factors Attract}, ",", "" ) ) ) + 0 ) * 2 + (IF( {Bonus Pull Factors}, LEN({Bonus Pull Factors}) - LEN( SUBSTITUTE( {Bonus Pull Factors}, ",", "" ) ) +0 ) + 2 ) * 1
You can see an example base here.
Here is the scores I would like added for each option chosen
  • Pull Factors Attract: 2
  • Bonus Pull Factors: 1
However it's not quite working with records with an empty field.
Best answer by Sho
This ought to work.
IF( {Pull Factors Attract}, LEN({Pull Factors Attract}) - LEN( SUBSTITUTE( {Pull Factors Attract}, ",", "" ) ) + 1 ) + IF( {Bonus Pull Factors}, ( LEN({Bonus Pull Factors}) - LEN( SUBSTITUTE( {Bonus Pull Factors}, ",", "" ) ) ) * 2 + 2 )
Forum|alt.badge.img+24
  • October 4, 2023
This ought to work.
