Help with issue with a comma ","
Topic Labels: Base design
347 0
Bruce_Franklin
I am seeing odd behavior with Link to another Record when it come to Commas.
If I have a comma , in a Single line text field then copy the field and paste it into another Single line text field I get a comma , as you would expect.
But if I have a comma , in a Link to another record field it is displayed as a comma , but when I copy it and paste it into a Single line text field the result is a comma surrounded by double quotes “,”.
Or if the value of the Link to another record field is used in a formula it returns a “,” instead of ,
Any idea why and if there is a way to fix this?
0 Replies 0
