How can I create a variable to use across my base?
  • April 19, 2021
  • 152 views
Hello, hope you don’t mind the newbie question.
How do you set a variable that I can call across
I have a base where I’m organising people into coaching groups.
Each coaching group has a unique name (Pacha, Twilo, Space etc). Each coaching group also has its own URL.
What I want to do
  • I’d like a field that autopopulates that Airtable URL whenever I assign somebody to a group.
  • So if I assign somebody to “Pacha”, another field updates with Pacha’s URL.
I guess that I need to create a table within my base to store these “variables” but I’m stuck on how to call them into the main table. I suspect it has something to do with linked fields and lookups, but whenever I read the documentation I get stuck.
Any help would be hugely appreciated.
Ian
Kamille_Parks11
Forum|alt.badge.img+27
It sounds like you need a table for [Groups], where each row is a group. There would be a column to store the groups’ unique url.
Then when you assign your other records to groups, you’d use a Link to Another Record-type field. Then you’d use a Lookup-type field to pull in the linked Group's {URL} field.
