How do I make a URL link usable again?
Topic Labels: Base design
672 2
Sean_Wilson
Super strange but I have an issue with airtable at the moment. Links are not clickable in the URL field sometimes. This is specifically if the table cell size is small.
It renders an entire webpage! How do I make this a normal link again so our users can actually CLICK on the thing?
18 - Pluto
18 - Pluto
That's super interesting!  I tried to replicate this and wasn't able to, and it looks like that Loom link works fine too.  Might be specific to something Neetorecord does?
As a workaround what if you used a Button field that uses the data from this field instead?
Sean_Wilson
I think it has something to do with the way that airtable unfurls links. If you select on the cell, the link is unfurled. You can actually play the video within the link also. If you make the cell height tall enough you can see the entire webpage theoretically.
which is obviously not what we want but yeah
