Issue in Airtable extension Block Release
  • January 9, 2024
  • 78 views
I am currently facing an issue while trying to release an extension created in Airtable using the "Block Release" command. I have encountered the following error: The block could not be found. Make sure your API key is correct and that you have access to the block.
Code: airtableApiBlockNotFound
I have verified that the blockId and baseId in the remote.json file are correct. Despite this, I am unable to proceed with the release. I believe I have the necessary access permissions, and my Access Token is accurate.
Here are the details of my configuration:
Nico_De_Ceulaer
Forum|alt.badge.img+7
  • January 19, 2024
I got stuck on the same issue today.
As I was still using API keys, I had to create a personal access token before I could run `block release`
And that is what caused the issue, I forgot to add the scope "block:manage" while creating the personal access token.
Regenerating a new PAT with the scope block:manage included fixed the issue for me.
