Apr 07, 2022 04:50 AM
hello everyone, I would like to change the primary field in the formula but it is grayed out and not editable, sorry but i can’t find the solution anywhere
Apr 08, 2022 02:49 AM
sorry, i can’t really find solution can you help me?
Apr 08, 2022 03:19 AM
Is your account set to either “creator” or “owner”?
If so, and you still can’t edit that field, I would reach out to support@airtable.com to ask them about this. Be sure to post back here with what they say!
Apr 08, 2022 03:29 AM
i’m a owner…I can’t understand why in some cases I can create it. I don’t think there is a limit to the formulas in the free plan
Apr 08, 2022 03:42 AM
Probably some bug. Let us know what they say!
Apr 08, 2022 09:18 PM
He answered me this:
Hi Francesco,
Alex from Airtable Support here ?? Happy to help!
It seems you are aiming to use a formula field as the primary field. The primary field (the first column in any table) can be configured as a formula, which takes data from other fields in the table to compose a unique name for each record. This can be useful if your table does not lend itself particularly well to a single unique primary field.
For more details, please feel free to check this article.
It’s certainly not a solution…I just can’t write inside the formula field…
