Using tags but seeing entries for every instance
  • April 19, 2020
  • 41 views
Hi there,
I’m using tags in a table to create groups for records e.g. ‘homepage’ , ‘landingpage’ ‘checkout’ . In a one to many relationships.
So, for instance, I have a table that has
Observations | Tags
record 1 | Homepage
record 2 | Homepage
record 3 | Landing page
Then in another table I’m seeing
Insight | Observations | tags
Name | record1, record, 2 | Homepage, Homepage
What I want is it to do
When I do a lookup on the tags on a separate table. What I see is a record with the same tag repeated several times as it is linked to several other records. How can I make it only display an associated tag once rather than for every instance?
Best answer by Mohamed_Swella1
Hi @Danny_hearn,
Welcome to Airtable Community !
Instead of Lookup use Rollup and in the Aggregation formula use ArrayUnique
BR,
Mo
Mohamed_Swella1
Hi @Danny_hearn,
BR,
Mo
  • April 19, 2020
Hi @Danny_hearn,
BR,
Mo
Thank you! that worked perfectly
