Morning!
This is probable really simple...but I'm struggling to find the formula i need and wondered if you lovely people could assist please?
Basically I'm trying to add a date in a formula output, so if the ccf column has a number in it copies the number across to the formula output column, and if the ccf is empty then it says 'no ccf 10/04/24'  (todays date)
This is as far as i've got - i cant figure out how to copy the info across or add todays date on - anyone know the simple fix for this please?
IF({CCF  *Customer order number*} >0,  "CCF ATTACHED", "NO CCF")
You can use BLANK() to identify when a field is empty
Also you can use the '&' text operator to join fields and strings together to  create 'no ccf 10/04/24' string.
For example something like this:
IF(CCF = BLANK(), "no ccf " & DATETIME_FORMAT(TODAY(), "D/MM/YY"), "CCF = " & CCF)
Result:
I'm using DATETIME_FORMAT to have the date in "D/MM/YY" format, TODAY to have the today's date.
I hope this helps. If you need more help feel free to schedule call with me. .
Result:
Thank you so much 🙂
