Formula result should not be more than a specific number
  • March 28, 2021
  • 7 replies
  • 63 views
Hi! How do I make it possible for the return of my formula to be not more than a specific number? Thanks!
MIN(number, calculation)
^ number = the maximum number
^ calculation = whatever formula you have that returns a number
Kamille_Parks11
Forum|alt.badge.img+27
  • March 28, 2021
Yay, it works! Thank you so much @Kamille_Parks ! <3
  • March 28, 2021
FF: So I’m using this formula: MIN(10,{Work Days}-{Absences}) but it doesn’t seem to perform {Work Days}-{Absences} when I’m putting a value on Absences HUHU
What do you guys think?
Kamille_Parks11
Are both {Work Days} and {Absences} numbers?
  • March 29, 2021
No, {Work Days} is a formula and {Absences} is number.
Kamille_Parks11
Okay, but does {Work Days} return a number? If the values in the column are aligned to the left the answer is no, if the values in the column are aligned to the right the answer is yes.
  • March 29, 2021
Yes, it does return a number and the values in the column are aligned to the right.
