Formula works natively in Airtable, but does not work from a Make (Integromat) Airtable Service mod
153 2
Richard_Foxwort
7 - App Architect
7 - App Architect
I am trying to build a module in Make (Integromat) that will find a single Airtable record that matches an AND + OR condition:
My formula is:
AND( {NMI}="XXXXXXXXX", OR( {Subscription status}="Active", {Subscription status}="Pending", {Subscription status}="Extend"))
If I create a dummy formula field in my Airtable  base and use this formula, it displays the value '1' (for 'True') in for the record I'm looking for, and all other records have the value '0' for False.
When I use this exact same formula in my Search Airtable module in Make, it does not return any matches
Any ideas on what could be happening here? I'm scratching my head...
18 - Pluto
18 - Pluto
Could the record be filtered out of the view that the scenario uses?
18 - Pluto
18 - Pluto
Richard_Foxwort
7 - App Architect
7 - App Architect
Thanks Kuovonne - this was a silly mistake that did result in the record being filtered from a view. Your answer helped me diagnose it.
