Help with detecting duplicates in a field
  • March 28, 2022
  • 66 views
I’ve attempted to follow the recommendations here to detect duplicates in a field but have not been successful and could use some expert eyes on what I’ve implemented. I did put a reply on that thread but since it’s a couple of years old, figured I should start my own question. Here are 2 screenshots from the 2 tables in play. Anyone see where I went wrong? TIA!
values is a pure array, the formula you wrote needs to handle strings. So replace all instances of values with ARRAYJOIN(values)
Kamille_Parks11
Forum|alt.badge.img+27
  • March 29, 2022
Thanks for the reply @Kamille_Parks
I thought the field {All IDs} being an ARRAYJOIN already would then be put into the Number of IDs rollup as the long text result of the ARRAYJOIN?
Kamille_Parks11
You’re doing a rollup of a rollup. So you’re still dealing with an array of strings, even though every record is linked to just one record its still an array.
  • March 30, 2022
Thank you for the explanation and this worked great!
Tito_Alverio
Forum|alt.badge.img+9
  • September 20, 2024
I needed a similar setup and this worked for me. Having a rollup detect when an email is used multiple times as a way to track a duplicate person entry.
