Help with grith formula
  • October 15, 2020
  • 38 views
Can anyone help provide a solution to this formula? I’ve tried it with ABS and IF.
(2*{width}) + (2*{height})
Best answer by EmA
I found my issue. The width and height fields were not # fields so I converted them and it worked using ABS function. Thank you for your suggestions!
Forum|alt.badge.img+8
Maybe try Sum(2width + 2height)
  • October 15, 2020
The formula looks fine to me. Can you include a screen shot that includes headings for the relevant field and some data?
  • October 16, 2020
