How can I best combined a column with a switch formula and another with a if/and formula?
  • November 1, 2022
  • 37 views
Hello! I have two fields. One titled: Naming Convention Help w/ this formula:
SWITCH({Naming Convention},"Series",{Standard File Name (Series) Template},
"Movie",{Movies - Naming Convention},
"Awards & FYC",{Awards - Naming Convention},
"Free",{Free Series - Naming Convention},
"Series V2",{Series Naming Convention V2},
"Series V3",{Series Naming Convention V3},
{Standard File Name (Series) Template})
and another formula field titled Naming Convention Final:
IF(AND({Language}&"" = "en-US", {Naming Convention}="Series V3"),{Series Naming Convention V3},{Naming Convention Help})
I’m completely stumped on this one and need to reduce the number of fields in my base, any way to combined these two fields into one?
Best answer by Justin_Barrett
Does this work for what you need? This was created by copying the SWITCH() function and completely replacing the reference to {Naming Convention Help} in the IF() formula.
  • November 1, 2022
  • November 7, 2022
Thank you, Justin! This works wonderfully, and the team is thrilled!
Cheers.
