How to write an IF AND formula
  • September 3, 2021
  • 46 views
I’m trying to create a formula where if two records are true it prints an answer. Here’s my formula: IF(AND({Role}= “Free”),{# Plans} => 5),“Cannot Add Plans”). I want it to show Cannot Add Plans if the Role = Free and the # of Plans => 5. It’s not working. Any help would be appreciated.
  • September 4, 2021
You need to remove the “)” after “Free” and flip the order of the operators after {# Plans} to “>=”. If the AND is still not happy, add more parens to completely separate the two boolean expressions. Good luck.
  • September 4, 2021
YES!!! Thank you so much!
