Is it possible to remove spacing between words using formula
  • April 15, 2020
  • 184 views
is it possible to remove spacing between words using formula
Best answer by kuovonne
Do you want to remove all spaces, or only some?
You can replace the space character with an empty string using the SUBSTITUTE function. It is documented in the formula field reference.
SUBSTITUTE({field name}, " ", "")
  • April 15, 2020
  • April 15, 2020
Thank you Kuovonne it worked perfectly :heart_eyes:
