Nested formula and DATETIME_DIFF not turning out, where is my simple error?
  • April 9, 2020
  • 14 replies
  • 90 views
Hello Airtablers!
For my CRM I’m trying to automate the ranking of my prospects from “ :fire: Flaming hot” to " :skull: Dead".
I tried using a SWITCH formula but got in difficulties, so I reverted to IF and DATETIME_DIFF.
I want to switch between the 6 values below and though I managed an IF statement with just 2 values, when I try 6 (and DATETIME_DIFF) I get no-where (I even checked for curly brackets, straight quote marks and the number or parentheses)!
Can you help?
I tried the following:
IF({Last Contact}=TODAY(),"🔥 Hot!",
IF((DATETIME_DIFF{Last Contact},TODAY(),'days')>3,"🌡 Warm",
IF((DATETIME_DIFF{Last Contact},TODAY(),'days')>7,"😎 Chilled",
IF((DATETIME_DIFF{Last Contact},TODAY(),'days')>21,"🚰 Tepid",
IF((DATETIME_DIFF{Last Contact},TODAY(),'days')<90,"🥶 Cold",
"💀 Dead!")
Thanks in advance!
Best answer by AlliAlosa
Hi there!
Looks like you’ve got some parentheses misplaced. For each time you’ve written…
IF((DATETIME_DIFF{Last Contact},TODAY()...
There is an extra parentheses after “IF”, and you’re missing one before “{Last Contact}”:
IF(DATETIME_DIFF({Last Contact},TODAY()...
The entire formula should look like…
IF(DATETIME_DIFF({Last Contact},TODAY(),'days')>3,"🌡 Warm",
IF(DATETIME_DIFF({Last Contact},TODAY(),'days')>7,"😎 Chilled",
IF(DATETIME_DIFF({Last Contact},TODAY(),'days')>21,"🚰 Tepid",
IF(DATETIME_DIFF({Last Contact},TODAY(),'days')<90,"🥶 Cold",
"💀 Dead!")
Hope that helps!
  • April 9, 2020
Hi there!
"💀 Dead!")
Hope that helps!
  • April 9, 2020
It also looks like you are using greater than signs instead of less than signs.
Most of your rankings aren’t reached because the formula stops evaluating when it finds the diff greater than 3.
Try using all less than signs and a final “else” condition.
  • April 9, 2020
Wow, plenty of simple errors I hadn’t even noticed!
Thank you, will give it a go and report back
  • April 9, 2020
My Google fu isn’t helping me find a cheatsheet for ‘else’ - what does it look like?
  • April 9, 2020
You’re actually already using the else condition. It’s the third parameter in the IF function. You can find the syntax in the formula field reference.
  • April 9, 2020
Do you mean the last bit - return skull if none of the above?
  • April 9, 2020
Yes, the skull is the final else parameter.
Technically, all of your nested if statements are also “else” conditions.
That is why I personally like to format nested if statements the following way:
IF(condition1,
  result1,
  IF(condition2,
    result2,
    IF(condition3,
      result3,
      result4
  • April 9, 2020
IF(condition1,
  result1,
  IF(condition2,
    result2,
    IF(condition3,
      result3,
      result4
@kuovonne - I do that by inserting the line by two spaces, right?
  • April 9, 2020
Hi there!
"💀 Dead!")
Hope that helps!
Oh dear, oh dear - now everything (even the really old contacts) are either ‘hot’ or ‘warm’ - no cool, tepid or zombies.
Should I put the list in order from largest to smallest? Does that help?
  • April 9, 2020
Did you replace the greater than symbols with less than symbols?
In general, when nesting if statements for ranges, start with the smallest number, and always use less than < symbols (or <=).
  • April 9, 2020
Looks like this:
      "🔥 Hot!",
      IF(DATETIME_DIFF({Last Contact},TODAY(),'days')<3,
        "🌡 Warm",
        IF(DATETIME_DIFF({Last Contact},TODAY(),'days')<7,
          "😎 Chilled",
          IF(DATETIME_DIFF({Last Contact},TODAY(),'days')<21,
            "🚰 Tepid",
             "🥶 Cold",
             IF(DATETIME_DIFF({Last Contact},TODAY(),'days')<120,
              "🧟‍♂️ Zombie", "💀 Dead!"
  • April 9, 2020
Ah, the result you are seeing is because DATETIME_DIFF subtracts the second date from the first date. If the first date is later, you have a negative result.
From the formula field reference:
The difference between datetimes is determined by subtracting [date2] from [date1]. This means that if [date2] is later than [date1], the resulting value will be negative.
Swap the order of {Last Contact} and TODAY() to get positive numbers.
Debugging formulas often works like this–fixing one error only to discover another one. Eventually you’ll get there.
  • April 9, 2020
Great! I got exactly what I wanted, and I learnt something too!
  • April 9, 2020
Sometimes that’s the best part!
I hope that you feel empowered to write and troubleshoot more formulas after this.
