Percentage Difference between two numbers
  • February 5, 2022
  • 124 views
I’m trying to figure out the difference (in percentage) between two numbers.
I’d like to set up a formula that gives the percentage (positive or negative) difference between two numbers.
So in the screenshot above
Row 1: Percentage decrease from 100 to 50
Row 2: Percentage increase from 25 to 50
Row 3: No change between 50 to 50
My formula so far: -(({Starting #} - {End #})/{Starting #})
Best answer by ScottWorld
Welcome to the community, @Diane_Martinez!
It seems like your formula should work. If not, you could remove that leading minus sign and subtract the starting # from the end # (instead of the end # from the starting #).
Then, on the formatting tab for your formula, choose “percentage” to display the number as a percentage.
  • February 5, 2022
  • February 7, 2022
That’s why it didn’t seem right. Thank you @ScottWorld!!
