Place a changing number for a column that is sorted from biggest number to lowest.
Topic Labels: Automations Data Formulas
146 1
0100371
I need a formula for the column on the right that writes a number 1 to the first result on the left, a 2 to the second result, etc.
I don't need an autonumber, this is because when the left column changes the numbers, the autonumber stays the same.
Is there any way?
Vic_Airtable
Community Manager
Community Manager
Hi @0100371
I'd recommend using a script either via the Run a script action or the Scripting extension. There have been some really cool scripts posted by other Community members to do just what you're looking for! Check out these posts:
Script Block: Rank Descending and Update Field
Ranking Field Calculation Script
Feel free to respond to those posts if you have any questions about getting your script set up!
