Jan 18, 2023 05:06 AM
I wish Airtable Regular expressions followed some common flavours so we could test it with regex101.com
I can make it work in these builders, but then when it comes back to Airtble #ERRROR. It's a huge potential but otherwise Airtable makes it hard to figure out why it isn't working.
I am trying to pull out the Patient's name from a Text extract. It always occurs after "Patient's name: " & before "Birthdate:"
Example string:
Radiology Report Patient’s name: Barney (57493) Birthdate: 7/5/2013
One Regex101.com, and regextester.com I can get it perfectly with this regex:
(?<=name: )(.*)(?= Birthdate: )
But when I put that in airtable:
Jan 18, 2023 05:44 AM
Jan 18, 2023 05:55 AM
Airtable REGEX formula functions are based on Google's RE2 library, which does not support the before/after features you are trying to use, among other things. It is the same library that Google Sheets uses.
If you stick to "simpler" regex expressions you should be okay.
