Vlookup between 2 tables and return sum total
  • August 21, 2023
  • 70 views
Nedra_Hines
Forum|alt.badge.img+10
I have 2 tables: “Home Staging Projects” and “Inventory Items”. In the “Home Staging Projects” table, I want to vlookup on the “Project ID” and return the sum total of “Rental Price” for each inventory item selected for that project listed on the “Inventory Items” table. I hope that makes sense.
I’m not sure if this makes a difference, but the “Inventory Items” table is linked to the “Home Staging Projects” table by (formula) “Project ID”.
Is there a way to use a formula for this?
Best answer by Nedra_Hines
OMG IT WORKED!!!! THANK YOU SO MUCH! I wouldn't have ever thought of that, and I've watched several Youtube videos to figure this out. I really appreciate it so much.
Forum|alt.badge.img+24
  • August 21, 2023
If they are linked, then the Rollup field can be used.
Rollup Field - Overview | Airtable Support
Nedra_Hines
  • August 21, 2023
I looked at both Rollup and Lookup and didn't see how to make it work.
  • August 21, 2023
Add a Rollup field to "Home Staging Projects" table
 Can you set it up like this?
Nedra_Hines
  • August 22, 2023
