An interface can only pull from one base.
However, you can sync views from other bases to a single destination table (or multiple destination tables) in a base. Then you can pull your interface from there.
However, note that the data will be read-only in your destination table, so that may be a dealbreaker for you. Also, when you sync bases, there is a maximum number of syncs that you can setup.
