Hide starting & ending hour in Interface calandrar views
Topic Labels: Interface Designer Views
121 1
TheFreeStyle
Is there a way to hide te starting hour and ending hour in calandar view ? It's a information that I can already see due to his position in the time grid and I would love to remplace it with another field more usefull like notes.
Best regards,
Simon
ProsperSpark
Hello TheFreeStyle,
Good question!  When the data field you use to plot on the calendar includes time in the data, it will also appear with time on the calendar view. (See below.)
You are able to add more information to the calendar view in addition to the time by using the "Customize Labels" button at the top of the calendar.
Specifically on a calendar interface, you can add more information by adjusting the "Fields" area on the left hand side.  You can add more information to the view by adding fields.
Good luck and reach out if you have any more questions~  You can find us here: prosperspark.com
