Jan 07, 2022 05:46 AM
Feb 14, 2022 03:58 AM
Hello !
I have the same problem trying to Group by on a Single Select field.
Thank you !
Feb 14, 2022 06:30 AM
Hello again @Andy_Scanlon !
I just found a workaround. The problem is that the Group by function doesn’t seem to work with Single or Multiple Select fields.
What I did is create another column with a formula just to transform the Single/Multiple select field into a string :
{Your field}
You should now be able to Group by on the new column you created !
