How to Filter Out Null Values in a Chart
  • September 5, 2023
  • 36 views
I am creating a chart that shows Purchase Orders grouped by status, but I am getting a group for "null." The status field is a drop-down single select with the 3 options below.  I've confirmed that the status of all records is not empty. I have also tried manually adding a filter to filter out records where the status is empty, but I still get the "null" group.
How can I get rid of the "null" grouping in the chart?
John_Baronian
  • October 25, 2023
Hi were you able to resolve this. We have a similar issue with no null fields in our y axis value.
If we change the field type to a number the null goes away but so do the color choices based on the type of select (single/multi).  I have a feeling that the "Add Option" select field is the Null that shows up....
  • October 26, 2023
Hey John, unfortunately I did not find a solution. I resigned myself to try to ignore the null group in the meantime.
