interface chart combine x-axis values
  • October 23, 2023
  • 62 views
Is it possible to combine multiples of identical x-axis values in the interface chart?
I have multiples of identical x-axis values and I want to combine those values into 1 bar.
I could make a special summary table with a roll-up but then the person using the interface would not be able to filter the records the way they want, so I need the chart to show all the records and be connected to the accessible filter element in the interface.
Best answer by Sistema_Aotearo
What type of field is your x-axis?
I would recommend using a "Single Select" field type. From there, do a bit of data management to match all the identical fields.
Sistema_Aotearo
Forum|alt.badge.img+20
  • October 25, 2023
Hi @Sistema_Aotearo ,
I actually ended up using a linked field instead of a single select, but your strategy worked perfectly thank you!
