Interface Element Filter for all Charts
  • June 9, 2023
  • 42 views
Trying to get get a common filter so users can modify dates or workflow status  and it will automatically changes the dates. I would like the users be able to add workflow status and/or modify the date range of the graphs and then update the data. How can I do this? Each chart is already connected to the filter element
Hi @rfscott2016, are you asking how to allow users to edit the filters? Try previewing your interface and clicking on the dates to modify them. It should update your charts automatically if they are connected to the filter element. Users of the interface will also be able to do this.
  • June 13, 2023
The dates work fine. Its the other options that do not see to make a difference when they are modified.
