I have some interfaces where list views are grouped by client name. I would like a "collapse all" or "expand all" function so that in those interfaces, it is possible to quickly expand all the lists or collapse them and then go one-by-one. The only "global" controls that I see are filter and sort. Are there others, or some way to do "collapse all" and "expand all" elsewhere? Thanks.
Interface Toggles/Controls (collapse/uncollapse) other than sort & filter?
Best answer by Sho
They are in the right-click menu.
