Saving Filter Settings in Airtable Interface
  • November 1, 2023
  • 394 views
Forum|alt.badge.img+12
I have an airtable interface that has a dropdown. When I select a value from the dropdown, it shows me some records in the gallery view. When I click on one of the field, it opens up details of a linked record in the list view. Now I want to show these results in the list view in a filtered format. Two of the values in the filter are supposed to be fixed and the third value can be changed by the user. Is there a way to do this using condition grouping? I tried to do it but everytime I publish the interface the filter vanishes. How do I save my filter settings?
I tried an alternate approach using filter dropdowns (screenshot below) but I am not too happy with the UI. I want location as dynamic which user can select and the values under More to be fixed. Is there a way to hide the fixed values but still filter the results based on the default values and allow user to only filter by country?
Sistema_Aotearo
Forum|alt.badge.img+20
Hello hello! I believe there are a few different filter levels.
You probably already have the "Allow users to set custom filters" on. This is where I'm guessing you've been trying to set the top-level filters. This won't work here as it's merely just fro the users to set their custom filters.
What you'd want to do is set a filter outside of this option
This filter will probably be on the list itself. If you can find the option "Users can see: all link records in {list field name}". From here you can set the default filters.
Not sure if this is what you were looking for but let me know. 🙂
  • November 2, 2023
Thanks for your response. However, I do not see the option to add a filter directly on the list itself. I assume the reason is because the list appears after a user clicks on the record details. I see the option 'Add element' on the main interface page. (screenshot below)
And when I click on the first record, I get to see a page like this (screenshot below)
I do not see an option of adding a filter element like I saw on the main interface page.
Is there a workaround for this? I am looking for the record to show me results that are filtered using two fixed criteria and then on the filtered results I want to provide the option to the user to filter by country. Filtering by country should be dynamic and in the user's hold.
Additionally I have another question. Now in the dropdown for country, I see all the countries from the table. Is there a way to show only the names of filtered countries in the dropdown and provide user with the option of choose from that filtered list?
Sistema_Aotearo
The filter won't be an element. It'll be a fixed filter that can't be changed by users.
In both these cases it's the same place on the right panel. You'll want to change from "All Records" to "Specific Records"
  • November 3, 2023
Understood. Thank you for the clarification!
