Unable to click notification to view comment
  • December 27, 2024
  • 46 views
Hello All!
New to Airtable but loving it so far!
I created a CRM for my company, and also created several interfaces for employees to use the CRM. Everyone uses the interfaces on the Airtable mobile app on their iphone.
One of the interfaces is a Referral Log, that allows users to add client referrals, comment, and keep track of them. Every employee has full access to this Referral Log interface, and can edit, create, etc.
I have built everything to be seamless, and it is perfect so far - save for one issue:
When a user comments on a Referral, or uses the @ symbol to add someone to the thread - they receive a notification that someone commented or mentioned them. This notification exists in the "notifications" menu in the apps base menus. However when you click into the notification a message appears "This page is not supported on mobile. Go to Desktop view." - the annoying part is you can easily just go to the record you were mentioned in and view the comment there, so the page is totally supported on mobile. This workaround is not seamless, and defeats the purpose of the notification directing you to the comment.
Is this an inherent bug in Airtable? Is there any work around?
Thanks in advance!!
Best answer by JeffreyW
Welcome to Airtable!
The issue you're encountering is indeed a limitation of the current Airtable mobile app design. Notifications for comments or mentions are designed to link to a view that the app doesn’t fully support yet, leading to that frustrating message.
If users rely on notifications for collaboration, ensure they enable email notifications in their Airtable settings. Email notifications include direct links to the mentioned records, and these links usually open the app or mobile-friendly views more reliably.
Also, consider adding a “Notes” or “Updates” field in your referral log. This would allow users to leave updates directly in the interface rather than relying on comments, which may have these notification quirks.
Hope this will help!
JeffreyW
  • December 29, 2024
